engine oil
Old Nov 18, 2009 | 03:34 PM
fireman's Avatar
engine oil
I just changed my engine oil using fully synthetic 10w30 and wonder should I continued to change my engine oil according to factory maintenance of 3750 miles or could I extend it to every 5000 miles?
Old Nov 18, 2009 | 04:08 PM
joedaddy1's Avatar
5000 is fine.. even maybe 7500.. get 5w-30
Old Nov 18, 2009 | 04:10 PM
Neu Era's Avatar
5000 is pretty good. I tend to keep mine at 3000-3500 range for synthetic.
Old Nov 18, 2009 | 04:11 PM
thescreensavers's Avatar
Mr.202?
I would not run 7500 unless your running Amsoil, and get a Oil report to make sure everything is ok.
read https://g35driver.com/forums/engine-...ysis-info.html
Old Nov 18, 2009 | 04:12 PM
Swivel's Avatar
Moderator
7500 is okay with Amsoil and most others but depending on the filter you used, you may want to change it halfway.
Old Nov 18, 2009 | 04:17 PM
Jeff92se's Avatar
Red Card Crew
blackstone labs
/thread
Old Nov 18, 2009 | 05:01 PM
soundmike's Avatar
Speaking of which, at the same mileage (5k), Blackstone found that my Mobil 1 EP is doing much better than the Pennzoil Platinum i had in prior changes, and to think i had a couple of track days on the M1.
Old Nov 18, 2009 | 05:13 PM
Jeff92se's Avatar
Red Card Crew
Mike, you referring to their 0-30? Yeah, that's supposed to be a very good version still. I don't think their 5w 30 / 40 or their 10w30/40 fares nearly as well against the others oils.
Old Nov 18, 2009 | 05:59 PM
fireman's Avatar
hmmm...so 5w30 will out last 10w30? by the way I'm using Pennzoil for the first time, I'm usually Mobil 1 kind of guy...
Old Nov 18, 2009 | 06:07 PM
Jeff92se's Avatar
Red Card Crew
no...
Old Nov 18, 2009 | 06:50 PM
joedaddy1's Avatar
lol. ok.
Old Nov 18, 2009 | 07:44 PM
soundmike's Avatar
5w30 on both. I'm a little confused, are you referring to the Pennzoil in your comment above?
I've used Amsoil and M1 for the most part, the Pennzoil was a fluke since it was all that was available locally for a while. Now that the M1 EP is fully stocked locally i was hoping to just keep using it.
Old Nov 18, 2009 | 07:50 PM
Jeff92se's Avatar
Red Card Crew
Oh you meant extended performance. What's that cost? More than the other Mobil 1 synthetics?
Old Nov 18, 2009 | 07:58 PM
soundmike's Avatar
Yep! The price varies, the Quart's tend to run between $5.5 to $6.5, roughly the same as the standard M1 Synth. The 5qt jugs come out cheaper, but it's still rather hard to find around here
Old Nov 18, 2009 | 08:03 PM
dofu's Avatar
20 Year Member
I used to use nothing but Mobile 1, but as of late, I'm just not a fan of Mobile 1 anymore. After discussing motor oils in a classroom with a rep from Redline, I've come to a conclusion that Mobile 1 sucks *****.
Motul > Amsoil > Castrol > Penzoil > Mobile 1
