Seat setting memory
Old Jul 31, 2012 | 07:02 AM
antodiaz's Avatar
Seat setting memory
Hi I just got a 07 G35s and Im trying to figure out how to set the seat setting memory. Thanks!
Old Aug 1, 2012 | 02:22 AM
vqsmile's Avatar
You can find it all in the free Owner's Manual that's available here:
http://x.infinitihelp.com/forum/loca...s.php?catid=56
(you do have to register before you can download it)
Old Aug 1, 2012 | 03:39 AM
kool_yaar's Avatar
^ thats a good site to register at for all future reference. but fyi from what i remember you need to first adjust everything(seat, mirrors, steering etc), then press and hold the 'SET' button until the '1' and '2' buttons led light up then let go of the SET button and simply press either button(1 or 2) where you want to save your settings.
im pretty sure this is how its done but its been a few years since i last did it
Old Aug 1, 2012 | 07:19 AM
Mo07G35s's Avatar
Here is copy/paste from the owners manual:
3. Adjust the driver's seat, steering
column and outside mirrors to the desired
positions by manually operating
each adjusting switch.
4. Push the SET switch and, within 5 seconds,
push the memory switch (1 or 2)
fully for at least 1 second.
The indicator light for the pushed
memory switch will stay on for approximately
5 seconds after pushing
the switch.
If memory is stored in the same
memory switch, the previous memory
will be deleted.
For manual transmission models, the
memory positions can be stored even
when the engine is running. In this case,
move the shift lever to the N (Neutral) position
and apply the parking brake. Then,
repeat steps 2 through 4.
Old Aug 1, 2012 | 11:33 AM
antodiaz's Avatar
Thanks a lot! I appreciate your help.
Old Sep 14, 2012 | 10:43 PM
G35XX's Avatar
kind of off-topic, but once in a blue moon I find the settings stored in memory a little bit off... that is after repeated recalls. It doesn't bother me alot, but it's kind of noticeable.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Albanian122
Aug 18, 2015 05:15 PM
Pcruz
Aug 12, 2015 07:46 PM
