Intelligent Key Warning Light flashing
Old Jul 23, 2013 | 11:22 PM
Afty's Avatar
Today after work I walked out to my '08 G35 sedan and found the battery totally dead. The doors wouldn't unlock, and it didn't turn over when I tried to start it. I noticed the Intelligent Key Warning Light flashing dimly in the instrument panel.
I got a jump start and drove home. At home, the Intelligent Key Warning Light continued to flash. I replaced the battery in my key, but it didn't make any difference. As far as I can tell, everything works fine -- I can lock/unlock the car and start it normally.
Has anyone seen this before? I'm hoping to avoid a trip to the dealer, but I also don't want to get stranded again.
Old Jul 24, 2013 | 01:53 AM
dukehotty's Avatar
Try an ECU reset now that everything is working. Use the gas pedal method instead of messing with the battery.
Old Aug 7, 2013 | 10:19 PM
mishmosh's Avatar
How old is your battery? If it's 3 years or older, just replace it. I had similar issues when my battery was going out. Replace it before you get stranded.
Old Aug 8, 2013 | 01:30 AM
dukehotty's Avatar
Your car battery was going out or your key fob battery?
tal1412
Nov 28, 2022 09:25 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
ghost_g35
Aug 7, 2015 10:31 AM
mjfenix
Jul 17, 2015 02:07 PM
