SPC Upper Control Arm Bushings
Old Nov 10, 2013 | 12:52 AM
An Lam's Avatar
Has anyone replaced the bushings on the SPC front upper control arm/camber kit #72130? Mines wore out after 4 years on my 2nd gen g35. Any info would be much appreciated.
Old Nov 10, 2013 | 02:24 AM
hurleyguys's Avatar
are those solid bushings? if not you can get the poly bushing from Energy Suspension or whiteline. i picked up the whiteline ones and cant complain.
Old Nov 10, 2013 | 03:12 AM
vqsmile's Avatar
Originally Posted by An Lam
Has anyone replaced the bushings on the SPC front upper control arm/camber kit #72130? Mine wore out after 4 years on my 2nd gen g35. Any info would be much appreciated.
By any chance, were they originally tightened down with the wheel off the ground and the suspension uncompressed?
Old Nov 10, 2013 | 11:53 PM
An Lam's Avatar
hurleyguys, Thanks for the reply. Those are the rubber bushings that came with the spc control arm. They look bigger than the ones on the stock control arm. Would u happen to know the model# for the whiteline that i can replace them with?
vqsmile, I followed a DIY from the forum and tightened the control arm with suspension loaded.
Old Nov 11, 2013 | 12:10 AM
hurleyguys's Avatar
on the whiteline website it looks like the W52988 bushings are what you are looking for.
Old Jun 6, 2014 | 10:59 AM
netcbc's Avatar
Is the bushings on the SPC the red ball thing?
Old Jun 6, 2014 | 11:59 AM
Lartytiejdke3's Avatar
That's the ball joint
CZP sells them for $75 each
Old Jun 6, 2014 | 12:12 PM
netcbc's Avatar
Thanks, this helps!
Freeman186
Sep 6, 2023 10:07 AM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
zcherub
Sep 10, 2015 12:03 PM
TheBay
Sep 3, 2015 03:27 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
