07 g35x
Old Oct 5, 2014 | 01:46 PM
charlieprodan's Avatar
07 g35x
I broke the bolts that connects the thermostat to the motor.
How do I get them out, without taking the whole front of the car off.
Help..... Please.
Old Oct 15, 2014 | 11:37 PM
vqsmile's Avatar
Help..... Please.
Did you ever get this fixed?
There are definitely ways to extract a broken bolt without removing the panel. Get yourself a left hand twist drill bit o little smaller than the solid part of the shank of the bolt. Use a small center punch to get the drill bit to center if you must, but be sure and get the hole started in the center of the bolt. As you drill down into the bolt, the left hand twist will sometime back the bolt out for you. If not, you have a nice hole to tap an Easy-Out into and back the bolt out that way. If it has thread-lock on it, you may have to heat it up a bit before it will break free and back out. This is something a good machinist will be able to, or at least advise you on. You can even look online for tutorials on removing broken bolts.
Good luck.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
