Car randomly not starting
Old Jan 3, 2021 | 08:46 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Reprograms the window motors, pretty simple on the V36.
Manual - pulling the switch to the first click
Auto-pulling the switch to the second click.
Turn ignition switch to ON (do not start the engine).
Roll the window down completely open manually, then hold up on auto until the window fully closes and continue to hold the switch for at least 3 more seconds.
Do this on each door that won't auto up/down.
Old Jan 3, 2021 | 09:03 PM
Crawford842's Avatar
G35 Sedan
this worked. And an update on the no start issue. It hasn’t been doing it. I don’t think I fixed anything(no loose connections or anything like that) so it may be something that will resurface at a later time. I’ll give it a couple days before I return the vehicle to normal usage.
Old Jan 7, 2021 | 12:00 AM
G35 Sedan
It’s back again. Gonna try to get a multimeter on that starter and see what kinda readings I get.
Old Jan 7, 2021 | 12:58 AM
G35 Sedan
And to accurately respond to the earlier question, it’s cold as **** out here right now at 10 at night and the car has been sitting in the driveway all day since morning. So it’s not a hot engine at all.
Old Jan 7, 2021 | 05:27 PM
cleric670's Avatar
BANNED!!!
Yeah that definitely sounds like a starting circuit issue not a starter issue. Be sure to use a metal brush to clean up both ends of the positive battery cable (and the connection points on the fusible link) to rule it out as well.
Old Jan 8, 2021 | 02:02 AM
G35 Sedan
no corrosion on battery or fusible link though.
Old Jan 9, 2021 | 05:51 PM
G35 Sedan
Anyone have any idea what this Little block with a green blinking light is? Is it stock or aftermarket? It seems like I can get my car to start if I push the button on it.
Old Jan 15, 2021 | 03:06 PM
cleric670's Avatar
BANNED!!!
Definitely aftermarket, follow the wire back and see if it goes to some kind of car alarm someone added. Might be what's keeping the car from starting.
Tyler Crabb
Oct 24, 2020 09:54 PM
Mr. G
Nov 10, 2013 11:38 PM
SAMzG35
Mar 6, 2012 06:05 PM
Roh
Jan 16, 2011 10:33 AM
LakeShore_Slate
Jul 25, 2010 03:00 PM
