V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Paddle Shifters on base model, problem!
Old May 3, 2008 | 03:48 PM
alti35's Avatar
I was installing the DIY for the paddles and when I got to the part where you install the paddles I found that there is no wiring for them. I don't understand, need help. Are the taped cables visible or do I need to getthem from behind somewhere?? I'm out ideas.
Old May 3, 2008 | 07:42 PM
alti35's Avatar
I am starting to believe that base trim cars do not have them. Anyone with base trim that have install them??? Right now I have them install, but they are dummies.
Old May 3, 2008 | 09:03 PM
Pdubz's Avatar
i have an 07 g35x.. dont know about yours.. but when i took my steering wheel housing apart.. it was right there but tucked in.. theres no way of missing it..
Old May 3, 2008 | 09:31 PM
alti35's Avatar
It is really strange, I thought it would have been readily visible, but there is no trace of the wiring. No taped plugs or anything. The funny thing is that they sold me the steering plastic casing for a base G35 (we don't have power column adjuster, it is manual). So it appears as if the paddles due exist for base trim.
Old May 3, 2008 | 10:05 PM
MikeYo's Avatar
i have them on my 07 base sedan.
Old May 4, 2008 | 01:28 AM
calibur45's Avatar
take a picture with all the housing off and post it for us
Old May 4, 2008 | 08:38 AM
alti35's Avatar
I'll try to post pics today. To see if you guys can help me.
Old May 4, 2008 | 08:43 AM
AesonVirus's Avatar
If they are there, they should be visible.
Keep in mind that the plug ends are wrapped in foam and tape... but I'm sure you know that and if you're anything like me, you've looked for those wires for hours now.
Old May 4, 2008 | 02:42 PM
alti35's Avatar
Here are some pics
Attached Thumbnails Paddle Shifters on base model, problem!-n121800167_31986643_8361.jpg   Paddle Shifters on base model, problem!-n121800167_31986642_7715.jpg   Paddle Shifters on base model, problem!-n121800167_31986644_8979.jpg
Old May 4, 2008 | 02:45 PM
alti35's Avatar
More
Attached Thumbnails Paddle Shifters on base model, problem!-n121800167_31986662_7345.jpg   Paddle Shifters on base model, problem!-n121800167_31986645_9596.jpg   Paddle Shifters on base model, problem!-n121800167_31986661_6708.jpg
Old May 4, 2008 | 03:24 PM
calibur45's Avatar
wow... i don't see the wiring for the shifters in those pictures.. anyone else install them on a base model?
also.. i see you are in puerto rico.. are the cars there outfitted differently from the mainland states?
Old May 4, 2008 | 04:05 PM
alti35's Avatar
As far as i'am concerned they should be the same. I have never noticed any difference from the cars in the island from the ones from the states.
Old May 4, 2008 | 05:23 PM
earth0's Avatar
I have installed it to my 08 G35X with No ploblems. try to locate at the sponge part (gray) or look at where the wired had tide together under the center of steering wheels
Old May 5, 2008 | 01:21 AM
calibur45's Avatar
anyone try this on a base model? i think most people who did this mod had journey or X
Old May 5, 2008 | 07:21 PM
alti35's Avatar
I have tried looking everywhere, but still nothin appears. I guess I'm stuck.
