V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Need some help installing interior lights
Old Apr 3, 2009 | 01:20 PM
BigDawg35's Avatar
I ordered the LED map lights, door lights, trunk lights, and license plate lights from Statik here in the marketplace. They came in today, but I've never taken any of these lights out before. I couldn't find a DIY sticky, so if anybody has one or could tell me the best way to remove and replace each of these I would GREATLY appreciate it. I don't want to bust anything trying to figure it out. I looked at the map lights and it wasn't obvious to me, so I thought I would ask for help. Thanks in advance!
Disregard. I figured out how to install them.
Old Jun 4, 2010 | 05:13 AM
dukehotty's Avatar
I ordered the same thing. The dome lights are very easy. You just pull them straight down and then stop because there is a little hook. Pretty durable so don't worry. I have not figured out the bottom door lights or the license plate lights. I have searched on the forum under DIY led and so forth with no luck. I tried the door light cover and when I really started to pull... the speaker was moving.. Let me know if you have any luck with info on the door and plate lights!
Old Jun 4, 2010 | 05:23 AM
dukehotty's Avatar
https://g35driver.com/forums/lightin...ights-led.html
Old Jun 4, 2010 | 05:53 AM
biggz786786's Avatar
the door light you should lie on your back, pop the plastic housing off, dont pull yet tho, the wire is still connected and is a bit of a pain to undo, if you have small hands then it should be fine, if not then try a small screw driver, basically its like taking out the ethernet cable from your internet modem, sqeeze and separate, then replace and connect and put back in
for the license plate lights, take off the license plate, and remove the light plate then lie on your back, then remove the plastic housing above the license plate area and pull off the bulb and put new one in
make sure the car is off and has been off long enough for the lights to cool down
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
derres
Aug 28, 2015 03:27 PM
EPG35
Aug 16, 2015 04:52 PM
Jadenkid22
Jul 14, 2015 12:33 AM
