V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Decreasing road noise
Old Oct 26, 2009 | 08:38 PM
markyrathjen's Avatar
Thought i would share a very inexpesive way to cut road noise in half....08g35x
1. I took off all 4 wheels( one at a time) then out came the wheel well cover
2. Then inserted a layer of SPL tiles from second skin audio on the underside of the wells...
3. Then i used peel and seal roofing materal for 2-3 layers inside the wheel using spray adhesive,
4. then i sealed then rest with a rubberized spray undercoating 4 coats
5. then i gave 2 coats of undercoating to wheel well liner itself both sides
6. put it back together... cuts road noise in half at 70mph, probably cost less than 100 or so.(tho it prob added 20# to the weight of the car)
This Can be done in one day too! I was quite suprised that is worked so well, its now lexus quiet without any of the soft handling, ( and now my bose systems sounds so much better)
New tires would have accomplished this as well, but that costs about 800$ and my Khumos still have 75% tread left, On the highway you only really hear wind noise which is very minimal
Old Nov 14, 2009 | 01:08 PM
kool_yaar's Avatar
^ Nice share. cant believe i missed it for this long, i might do this in the summer to cut some road noise though i dont think its that bad stock, making it even quieter wont hurt thanks
Old Nov 14, 2009 | 01:27 PM
4DGS's Avatar
You can also go to a Ziebart or something and they can do a noise deadening spray for around $150, they spray the underside of the car and the wheel wells.
Do you guys have Ziebart in the states? It might be more money I got special pricing from a friend who owns one, might be a little more. I road in a charger(srt8) that had it done and it was kind of sad that I couldn't hear the exhaust, but it was a very comfortable level inside the car.
I haven't put my new wheels on yet, but they have continental sport tires that almost look like slicks, I am worried they are going to sound load as hell so I might be doing this. I am trying to cut weight on my car though
Old Dec 14, 2009 | 12:20 AM
docaam's Avatar
Do you have the names of these things which you applied as im sorry couldnt get anything out of it
Old Nov 16, 2010 | 10:28 PM
typesblkura's Avatar
BUMP...has anyone personally heard from markyrathjen?
Old Dec 2, 2010 | 02:15 PM
Roblinds's Avatar
yes the car does make a lot of road noise- or i should say allow in alot of road noise --- i want to know how do you remove the we whell well covers exactly..... id like to do this upgrade if its not a nightmare getting the covers off. any info links to it?
Old Dec 7, 2010 | 05:11 PM
gtbigup01's Avatar
Couple snap in fastners, (3) 10mm bolts, a few screws. Not trying to be a smart **** but if you take your wheels off and look under there you'll figure it out.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
alinero718
Sep 27, 2015 09:35 PM
