V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Interior power source?
Old Nov 12, 2009 | 04:19 PM
simsimi1004's Avatar
I bought 4 LED strips for foot area illumination, (strip of leds with + and - wires on the end)
Where can i tap into to power this? i need a 12v power source..
My plan is to put 1 each where foot rests, 2 in the front and 2 in back
Discreet is key.
Can anyone help me out? Also, how i would hide my wiring....
any help would be great
thanks.
Old Nov 12, 2009 | 05:04 PM
Austin713's Avatar
you could tap into a 12V switched fuse at the fuse box in the kick panel by the drivers dead pedal, then just hide your wires in the kick panels. it is going to be a PITA though. you know Infiniti sells an ambient lighting kit from the factory.. it plugs straight in i believe. riverside infiniti has it for a little over 200 i think
Old Nov 13, 2009 | 03:08 AM
pfarmer's Avatar
Discreet is key.
thanks.
Depends on how you want them to turn on. If you are just after power you can actually in many cases just pull out a fuse, put in a fuse tap and replace your fuse.
Old Apr 28, 2010 | 06:58 AM
bump. pushed it off and coming back to it now.
i would like them on via a switch or when headlights are in use.
i know nothing abotu fuses etc so any detailed help would be great.
neight
Interior
Sep 21, 2015 05:35 PM
gatorglaze
Sep 10, 2015 12:03 PM
zcherub
TrillO.G.35
Sep 5, 2015 02:06 AM
