front lip owners
dont really need a template or manual, jest get some short screws or self tapping screws that will fit through the holes on the lip and if the lip does not have 3M doubleside tape just pick one up and apply on the entire top and side.
Then pop on the lip onto the bumper(it will actually pop on securely thus eliminating the need for any templates, uncover 3m tape and attach, then using a power screwdriver or drill, screw in the screws and ur all set, 20mins tops
I've installed a few of these now.
The templates need to be cut out, placed precisely, holes have to be marked, templates have to be removed and then the lip has to be lined up with the holes.
Honestly, the lip fits very securely with little to no wiggle room to allow it to be "off".
My next install, I'm not going to use the templates... they're honestly not needed.
Pop the lip on, mark the holes and drill them. HIt the holes with your screws and remove the tape backing.
Doing it this way, you're looking at a 15 minute install with the same results.
I believe they have every available color in the 09's. If SS was available in 09 I'm sure there is a front lip for it.
Going to the hardware store today to see what I can pick up.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
