V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Trunk light wiring
Old Jun 18, 2011 | 09:52 PM
surfjax87's Avatar
Trunk light wiring
Does anybody here know where the wiring for the trunk light runs? I could only find info on removing the bulb, nothing about the wiring.
I picked up a couple led strips to use to light up the trunk and need to tap into the trunk light wiring. The bulb receptacle is mounted to the rear deck, so am I going to have to remove the rear deck to get to the wiring?
Old Jun 19, 2011 | 01:57 AM
kool_yaar's Avatar
you can see and use the wires from inside the trunk without having to remove the rear deck. the carpeting is easy to take off.
Old Jun 19, 2011 | 06:50 PM
zoop425's Avatar
That or just get a little wedge base adapter.. easy stuff
Old Jun 19, 2011 | 06:59 PM
surfjax87's Avatar
I couldn't find where the wiring was without major searching, so I made an adapter. Used an old 194 led bulb, was blue so I didn't need it, and just made my own leads for it.
Old Jun 19, 2011 | 07:03 PM
zoop425's Avatar
there you go!
Hasanbaloch
Feb 29, 2024 08:45 PM
tal1412
Nov 28, 2022 09:25 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
linedr89
Aug 17, 2015 05:11 PM
