will these bulbs fit?
I am thinkin of replacing parking lights, fog lights, and turn signal bulb
Here are my picks:will they all fit? especially the turn signal that concerns me, if its going to fit through the bulb opening.
any suggestions would be highly appreciated
thnx
thnx
no so sure on the turn signals.. I see you can get the resistors to prevent the fash flashing. However I'm confused by their 'dual mode' descrption - the driving/parking lights dont normally change colors when the signal is on. Mine were orange from the factory and I swapped them for leds - but as far as I know, turn signals are not dual mode on our cars. Maybe that's a G37 only feature or it required some wiring changes?
I attached pics of the leds I used if that helps - they all fit on my 08 g35 sedan. (The fogs are 9006 bulbs, so you can put whatever in there as long as its 9006.
I have to warn you about the parking lights. In my experience, buying very similar bulbs from idjmtoy resulted them from burning out in a matter of 2-3 months max. Granted, I am also running a white Hoen DRL setup, which may be heating the housing a bit and reducing their life. I bought
which also burn out but seem to last twice as long before going.
