V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Paddle Shifters - How to tell if my G35x is prewired?
Old Aug 3, 2012 | 08:20 PM
chris2k5's Avatar
I am about to order the paddle shifters for my G35x 2007 model. I was told that not all G35's are prewired though. How do I tell if mine is pre-wired for the paddle shifters?
Old Aug 3, 2012 | 08:47 PM
EbbAndBlow's Avatar
You just have to pop off the steering wheel column trim pieces. Or take off the steering wheel first, then check if the connections are there. They are two identical white-ish dongles inside of the column. And they should be bound by elastic or twist-ties.
And after many failed attempts, I finally found the DIY.
https://g35driver.com/forums/v36-diy...t-paddles.html
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
gatorglaze
Sep 10, 2015 12:03 PM
