V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Quick Question (Halo's)
Old May 16, 2013 | 11:51 AM
RJ01's Avatar
I have an 07 G35 SEDAN, and I was wondering what should the size of the halo be on the outside of the shroud , 80mm or 90mm ? (i.e. how large is the ring on the outside of the shroud)
Old May 17, 2013 | 01:17 PM
RJ01's Avatar
bump
Old May 17, 2013 | 07:37 PM
mishmosh's Avatar
Don't do it. Heat is the enemy of all LEDs. Inside the headlight, there is no ventilation. No cooling. Your aftermarket LEDs will burn out eventually and it is a royal pain to open them up again. Paint the shrouds back and at some DRL LEDs if you want some bling.
Old May 17, 2013 | 07:50 PM
RJ01's Avatar
Thats a good point and I don't want to go through the hassle of opening them up again ... I think i'll just stick with doing:
Flat black housing
Color matched projector and parking light shrouds
Sti-R clear lense swap
What do you think of the LEDs?
Old May 17, 2013 | 07:58 PM
mishmosh's Avatar
Not my style. I did install DRL LEDs in the fake vents of the bumper, cause I do like bling though :-).
Also, as for the STi lenses... really this is something only you will notice. And only in certain situations like in front of garage. Sharp cutoff, uniform colors? Not worth the money in my opinion. I don't know if you read the horror stories about trying to get the screws loose...
Old May 17, 2013 | 11:32 PM
RJ01's Avatar
Yeah heard about those stories ...but any way your words of wisdom have got me thinking and I'm just gonna go with painting the headlight flat black and colour matching the two shrouds
Old Aug 10, 2014 | 07:05 PM
Speeddemon15026's Avatar
Flat black housing
did you install those less? i really like them, if so can you send me a link the the ones you used?? thanks!
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
julian.dion
Lighting
Jul 29, 2015 08:33 AM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
Soumilg
Jul 18, 2015 12:33 PM
