V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
DRL passenger side not working!
Old 07-20-2016, 05:14 PM
invincible514's Avatar
Exclamation DRL passenger side not working!
Hi guys, my 07 g35x passenger side DRL is not working anymore, i tried to check if it was the fuse that was done, but couldn't find the fuse location, checked the fuse box inside under the steering wheel and the fuse box near the Battery, still didn't find anything.
-if i do have to change my Bulb, does any one know the standard size or the model number if there is one? sorry I'm a complete noob, so your guys assistance would help out a lot!
Old 07-20-2016, 05:50 PM
vqsmile's Avatar
See Owner's Manual, pages 8-25 to 8-27.
EDIT: If you don't have a manual, here's one for an '08, which is virtually identical : https://owners.infinitiusa.com/conte...-G35-Sedan.pdf
The page numbers change to 8-24 to 8-30 though.
invincible514 (07-20-2016)
Old 07-26-2016, 04:35 PM
bulb replaced but a new problem
hi guys , i went ahead and replaced the build but after the complete procedure, now i have a check engine light that popped up :S, any one went through the same symptoms? your guys help would be really appreciated!
Old 07-26-2016, 06:40 PM
vqsmile's Avatar
Get the CEL code and report back here. Without it, anyone would just be guessing as to what is going on now.
Old 09-09-2017, 12:55 AM
Samuel Kwok's Avatar
Did you ever fix it?
Both of my bulbs just die after an emptied battery.
TheIronYuppy
04-11-2016 03:25 PM
06g35
Lights
03-29-2016 11:41 AM
cheezstik
03-28-2016 03:15 AM
2014g35x
03-17-2016 10:02 PM
Richsqrd
02-18-2003 12:53 PM
Quick Reply: DRL passenger side not working!
