ICHIBA USA Aluminum Wheel Spacers 5MM, 10MM, 15MM, 20MM & 25MM In Stock Now!
Old Jan 4, 2007 | 07:03 PM
ichibausa's Avatar
This is long wait but finally they are all available now!
ICHIBA USA Aluminum Hubcentric Wheel Spacers www.ichibausa.com
5MM Aluminum Wheel Spacers $59
10MM Aluminum Wheel Spacers $99 ***New Item***
15MM Aluminum Wheel Spacers $99
20MM Aluminum Wheel Spacers $109
25MM Aluminum Wheel Spacers $129
Again, they are all in stock & ready to ship!
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Infiniti Spec:
Bolt Pattern: 5/114.3
Center Bore: 66.2
Thread: 12x1.25
Longer Studs Included
Old Jan 5, 2007 | 12:38 AM
TwoK4drSi's Avatar
10mm spacers you have to change the studs?
Old Jan 5, 2007 | 04:01 AM
ichibausa's Avatar
Yes for sure.
Old Feb 12, 2007 | 05:38 PM
ichibausa's Avatar
bump!
Old Mar 6, 2007 | 12:23 PM
SuperShick's Avatar
how do you know which size to get?
i have PIAAs with 19x9F and 19x10R both at +25 offset...you think for the 03 coupe, if I get the 10mm spacers and make them +15, it'll fit just fine or that'll stick out?
anyway to find out how perfect it'll sit?
Old Mar 6, 2007 | 02:42 PM
ichibausa's Avatar
You might need to put the rims on first. Measure the gap between the fender and your rim. The gap size is what you need for wheel spacers. Here is the link http://www.ichibausa.com/whspad.html
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
