Camber arms to prevent cupping
Old Jun 7, 2006 | 12:32 PM
Gashed's Avatar
Not schooled in camber kits so I need your folks advice. If I was to install an aftermarket camber kit on my '04.5 coupe would that give me the ability to adjust such that the tire feathering issue / cupping issue would go away?
Thanks!
Old Jun 7, 2006 | 01:59 PM
kenchan's Avatar
not necessarily as the aggressive toe angles are probably what's causing it.
Old Jun 7, 2006 | 02:48 PM
caskyline's Avatar
Former Vendor
Camber is the inner or outer wear on tires......Toe is the feathering of the tires.....cupping is indication of worn out shocks.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
