Stillen's Rear Camber Adjusters
Oct 8, 2003 | 03:27 AM
Re: Stillen's Rear Camber Adjusters
hey wreck, keep us updated on how the camber kit fits
Reply 0
Oct 8, 2003 | 03:28 AM
I just got back from hawaii. I'll try to get them installed this weekend. i'll let you know how they work out. I think I got the kits delivered already. I just came home with a UPS slip saying I have a package and my neighbor signed for them. It's to late to knock on the door to get them.
G35C 6MT / AMG E55
Reply 0
Oct 8, 2003 | 03:42 AM
i ordered the camber and traction kit. Now I'm waiting for my HKS coilovers and tires
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
Reply 0
Oct 8, 2003 | 08:46 AM
FYI - the rear camber is adjustable from the factory. My camber was -2.33 from the factory and was adjusted to -.50 for the cost of an alignment only.
ZEX wet kit 140 WHP
ZEX remote opener, bottle heater
Denso iridium 2 steps
Z tube, Amsoil filter
JIC-Magic traction rods
BFG Drag Radials 265/40/18
12.85 @ 108.5
Reply 0
Oct 8, 2003 | 10:53 AM
Juice, you are one of the lucky ones. My alignment shop said they can't get it to spec with with the stock adjuster washer.
G35C 6MT / AMG E55
Reply 0
Oct 8, 2003 | 01:09 PM
yeah but these polished stainless camber arms sure look better than the black factory ones!
2003.5 G35 Silver/Graphite 6MT Premium Coupe
19" Gunmetal TE37s & 275/30 Michelin Pilot Sports
kg/mm supersport springs
Alpine/JL Audio/Stinger
double din, he-he-he
Reply 0
Oct 8, 2003 | 05:20 PM
Just finished installing and aligning my wheels.
Camber bar works great. The craftsmanship on the camber bar is superb.
Here is my NEW problem. When I asked to set the camber to -1 my left rear could not get the toe to spec. My rights was perfect. Cause of the toe couldn't get into spec, I had to find a happy medium and had to settle with -1.9 degrees in the rear. I really wanted 1.3ish.
I'm still trying to figure out why the left rear is like that. I'm guessing it is a bit lower than rights. As mentioned on the board, people that have installed the eibach mentioned the left rear is lower than the right.
PS. I forgot to add that my camber was -2.5 before.<P ID="edit"><FONT class="small"><EM>Edited by wreck on 10/08/03 02:29 PM.</EM></FONT></P>
Reply 0
Oct 8, 2003 | 05:34 PM
wreck,
you got the ones from lsdunique on 350z correct? I just got those and was wondering if they were hard to install. so they work great and look great?
Reply 0
Oct 8, 2003 | 05:43 PM
Yah I got them from lsdunique. Once I realized I couldn't jack up the car safely and work under my car, I went to a local tire shop (been going there for over 10 years) and had them do it. The charged me $95 with alignment. It took them about 1.5. It's cool watching the numbers change on the computer screen when they made the camber and toe adjustent. It was frustrating to see my left rear toe out of spec when the camber was set to how I wanted it.
They worked perfectly. They look good too.
G35C 6MT / AMG E55
Reply 0
Oct 8, 2003 | 06:00 PM
Here are some pics.
G35C 6MT / AMG E55
Reply 0
Oct 8, 2003 | 06:02 PM
another
G35C 6MT / AMG E55
Reply 0
Oct 8, 2003 | 07:52 PM
so since you can't get the left rear to spec, does this mean that you need the traction kit as well?
AIM= bkchang79
Reply 0
Oct 8, 2003 | 08:05 PM
I got the camber to spec just not the toe (left rear only). I'm not sure if I'm going to spend another $200 on the traction kit. I'm still trying to understand how the traction kit will fix the toe.
G35C 6MT / AMG E55
Reply 0
Oct 8, 2003 | 10:49 PM
cool, they look great, i cant figure out the traction bars either so i ujust got the cambers, i am glad you can see them that well from behind, i think im gonna get mine powdercoated blue so they will match my springs and sways. either that or polished.
Reply 0
Oct 10, 2003 | 03:58 PM
  #30
Finally got my cam kit instgalled (LSDunique?). The specs for the rear are 1.5. The fronts are off, but there are no kits available. The car handles much bette and it seems quieter - maybe the camber made the wheels ride odd and thus produce more noise or it could be my imagination.
Either way, great combo - Eibachs and Cam kit.
G35 Coupe 5AT, DP, Tire and Wheel Pkg., Aluminum Pedals, Clear Corners, missing turbo
Reply 0
