Any reason the donut spare.
Old Jul 19, 2006 | 11:10 AM
fortified's Avatar
Can not be swapped with this? Saves weight & space and according to manufacturer is safe with TPMS sensors as well as run-flat tires.
http://www.tirerack.com/accessories/...tkit/index.jsp
Old Jul 19, 2006 | 11:24 AM
GLuXuRy's Avatar
Some BMW's have that.. like the e60 ///M5
Old Jul 19, 2006 | 11:58 AM
truplay8's Avatar
THE BATMOBILE
go for it
Old Jul 19, 2006 | 01:02 PM
G3NIU5's Avatar
so it's liquid like the fix-a-flats? some tire shops are picky and might not fix your tire when they know it's filled w/ those. it's quite messy.
Old Jul 19, 2006 | 01:20 PM
johnadlertech's Avatar
I still dont know about putting glue in the sensor. And it if the sidewall or rim was damaged it wont do the job. I like a real spare tire.
Old Jul 19, 2006 | 04:29 PM
kenchan's Avatar
i would also stick with the spare.
Old Jul 19, 2006 | 06:24 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I wouldnt wanna be stuck on some dark road in the middle of nowhere, beacase i didnt have a spare, and the fix-a-flat didnt work
Old Jul 19, 2006 | 09:33 PM
fortified's Avatar
I think this is a much better system than fix-a-flat. It is simply a compressor (and those rarely fail) and the sealant is injected in the air stream. With fix-a-flat there was always the concern whether there was enough air in the can to totally pump up the tire. I think in most cases it pumped enough to be marginally usable to limp home.
I understand the reservations. But a donut is a poor excuse for a tire, especially if you are a long way from help. Not saying that's a likely scenario.
Most soft tires seem to happen close to home, and of course when you are in a hurry. But saving the weight would be nice too.
I will have to read up up on it more. Especially if there are problems permanently repairing a tire because of the goo.
Old Jul 19, 2006 | 10:01 PM
Triple8Sol's Avatar
I would rather just roll w/no spare and no fix-a-flat. Just call roadside assistance
Old Jul 21, 2006 | 09:05 AM
fortified's Avatar
Not a bad idea.. the plastic ID card weighs almost nothing at all!
Old Jul 21, 2006 | 01:18 PM
kenchan's Avatar
im sure RSA can plug your tires, but if they have to flat bed it, does
the G's lip clear the bed when it's being loaded?
