Edit: Mounted my GT-C's today...
Old Jul 29, 2006 | 10:04 PM
mr.almeida's Avatar
So today I woke up at 5 AM to pick up my GT-C's at RZ Motoring in Orlando. (I live in Broward County) I get there on time at 10:30 AM pick them up as if everything was fine and then go home to mount them, because I wouldn't be able to fit the stock rims in the car, so I brought a truck with me. I get home at 4:30 PM and I become very upset...
Hmmm... looks like the fronts have a +21 offset, which does not fit the damn G35! I check my receipts and the first one says that they are +24 offset and the second one I got when I picked them up says +21. I hope this was an honest mistake by the shop, but damn I'm so pissed off. I wait 3 months and then +3 more of an offset holds me back from mounting. I need to vent. I have to call them up Monday and see what's up.
*EDIT*
Old Jul 29, 2006 | 10:31 PM
Driver UR G's Avatar
i know what that feels like.sorry man but think of it this way thats less time ur gunna take a chance of fcuken ur rims up
Old Jul 29, 2006 | 10:37 PM
Chico's Avatar
explain exactly what it is that doesn't fit? are you talking about NOT clearing your brakes? or you simply can't mount them on the hub?
Old Jul 29, 2006 | 10:46 PM
mr.almeida's Avatar
I can't fit them on the hub... I put the hub ring on and it's off because the offset isn't right. To prove that it's the offset I took the hub ring off and when it wa flush against the rotor the lug pattern was still off.
Old Jul 29, 2006 | 10:48 PM
eyustfu's Avatar
wrong bolt pattern? check the sticker on the inside of the wheel
Old Jul 29, 2006 | 10:57 PM
Chico's Avatar
that doesn't make sense...the hubring sits flushed inside the center bore of the wheel and right up around the hub. Are you trying to put on the front ones? if so, there is an extra bolt that has to be taken off so you can properly mount your wheels. 3mm difference in offset will NOT cause the problem you're describing.
mr.almeida's Avatar
I think it's the offset...
Old Jul 29, 2006 | 11:00 PM
mr.almeida's Avatar
I didn't try that. Jeez I'm an idiot let me go try it right now.
Old Jul 29, 2006 | 11:39 PM
bikesbikes's Avatar
Yeah make sure you remove the little bolts. They're there so you don't mount the rear oem rims on the front.
+21 should fit no prob. I've got +17 on the front and they're fine.
Old Jul 30, 2006 | 12:56 AM
mr.almeida's Avatar
Thanks guys. I'm an a-hole. Everything's fine now.
Old Jul 30, 2006 | 01:08 AM
Chico's Avatar
glad it worked out. let's see them on the car.
Old Jul 30, 2006 | 01:37 AM
dR6's Avatar
dR6
All this, and no final results pics?
Put 'em up and show them off!
Old Jul 30, 2006 | 02:00 AM
izmir41500's Avatar
G35driver Addict
+1 time for pics now.
Old Jul 30, 2006 | 06:26 AM
mr.almeida's Avatar
LOL everyone calm down. It was 12:15 AM when I put them on this morning and I have to go to work in 30 minutes. Check back by the end of the day.
Old Jul 30, 2006 | 11:28 AM
escobar929's Avatar
lol, you dont know how many people this has happend to
