Will TPS work on Volk SF Challenge?
Old Jul 30, 2006 | 01:13 AM
jxtg35's Avatar
If anyone know for sure that our TPS will work on SF Challenge please chime in. Looking to buy a used set of TPS but I wanna make sure they will work first.
Also once I install them will I have to go to the dealership to have them set to my car so that my TPS light goes off? Are you able to tell them what PSI you want the TPS set to or are they factory set and unchangable?
Thanks
Old Jul 30, 2006 | 01:17 AM
rookie's Avatar
I don't know if they fit those wheels but they can always be banded to the wheels.
Yes any new sensors you want the ecu/bcm to monitor will need to be registered using the consult II. I don't know what the alert psi is for the Gs, for the FX I think it's 29psi.
Old Aug 3, 2006 | 01:42 AM
ssk0771's Avatar
ZZ Boy
Its possible but you will have hard time putting air in since TPS is NOT L shape.
Old Aug 3, 2006 | 09:33 PM
GReddySetGO's Avatar
No, it will not work as replacement of the valve stem. The only way to do it is to band them around the rim.
Old Aug 29, 2006 | 02:38 PM
BananaKing's Avatar
Band them to the rims? How? And what parts necessary to do this? I'm interested in finding out as well.
Old Aug 29, 2006 | 08:08 PM
Andy2434's Avatar
Chris at F1 can make the TPS work with the Winnings, soooo . . . I think that he should be able to do the same in kind for the Challenges.
Old Aug 29, 2006 | 08:34 PM
2004v35's Avatar
more info please
Old Aug 29, 2006 | 09:56 PM
nm3th's Avatar
^^^ check this out...
http://www.my350z.com/forum/showthread.php?t=186197
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
EPG35
Aug 16, 2015 04:52 PM
neight
Aug 3, 2015 11:27 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
