Can I use oem 19' tires on volk le37t or racing hart j8 pro?
Old Aug 6, 2006 | 05:01 PM
bird2730's Avatar
How does this look? I don't want to have a bigger wheel gap than stock, and I don't plan on lowering the car since its a headache to deal with. Plus, I only have 3k to play with so my options are somewhat limited. please post pics if you have this setup or if this is recommended.
Old Aug 6, 2006 | 06:29 PM
redlude97's Avatar
if you go with 8.5F/9.5R, then you can probably use the stock tires, they will look stretched, but it will probably work ok. Won't work on a 10.5" rim however, so that may limit your choices, not sure if the j8's come in those sizes
Old Aug 7, 2006 | 02:15 AM
mark4x4's Avatar
Your main concern is the overall diameter of the wheel. Your OEM fronts are 225/40/19 which are 26.1" in diameter the equal tire size of 255/35/19 is 26" in diameter which would give you the same gap in your wheel well. Your rear OEM's are 245/40/19 which is 26.7" which would equal the size of 275/35/19, which is 26.6" or you could go with 285/35/19 which is 26.9", a tad taller.
Go to www.rims-n-tires.com and on the bottom right hand corner click on the link that says "size comparer". You will see how and compare different size tires, it will give you all the info you will need to know to make a informed decision.
Hope this helps...........
Old Aug 7, 2006 | 02:56 AM
truplay8's Avatar
THE BATMOBILE
jst keep your stockers until the tires are bald and then get new wheels and tires........go with the volks
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
doublej32
19 Inch
Jan 28, 2016 08:42 PM
kevintandmd
Sep 3, 2015 06:41 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
