will these wheels fit??????
Old Aug 8, 2006 | 12:07 AM
FriscoD415's Avatar
Bolt Pattern: 5x114.3
Size: STAGGERED- FRONT IS 20"x8.5" AND REAR IS 20"X9.5
Offset: front IS +32mm AND REAR IS +35MM
was wondering if these offsets will fit my G without any modifications having to be made????
Old Aug 8, 2006 | 12:15 AM
ttrank's Avatar
Grocery getter
SEARCH!!!!!!!!
This topic has been discussed so many times.
Old Aug 8, 2006 | 12:54 AM
woshiagni's Avatar
^^ yes... search...
there is no short answer. it depends on 1) if you lower your car 2) if you tend to carry backseat passengers a lot 3) what kind of roads you drive on and 4) what width/profile tires you install.
but to help you out, that width with those offsets will most likely rub unless you roll/cut your fenders and run stretched tires.
Old Aug 8, 2006 | 02:44 AM
ttrank's Avatar
Grocery getter
if you roll your fenders
if you cut your fenders
Please search, I have posted in this same topic thread so many times and have not been a member for that long. I searched 50 times for each time I posted when I first became a member; maybe I expect too much from others.
Where is Cru? He would go off right now.
Old Aug 8, 2006 | 03:15 AM
skeleton_cru's Avatar
Sedan
I'll answer 'cause he's from the Bay Area...
You will likely rub the front fenders and will definitely rub the rear fenders. You need bigger offsets. +38 front, +45 rear, especially if you lower your G.
Old Aug 8, 2006 | 12:15 PM
az1anbeethoven's Avatar
you will have a prob in the rear if you dont roll...
Old Aug 8, 2006 | 01:19 PM
ttrank's Avatar
Grocery getter
Wow Cru, I was expecting some flaming.
Anyway, yes they will rub. The rears might fit if you cut/roll your fenders but they will be very close.
Old Aug 8, 2006 | 02:21 PM
codeflux's Avatar
no, this offset is too low. these wheels will not fit.
however, these will: https://g35driver.com/forums/archived-sales/106630-fs-19-volk-le37t-gunmetal-chrome-staggered-w-michelin-pilot-sport-tires.html
you know you want them. they'll be perfect.
Old Aug 8, 2006 | 11:43 PM
Sedan
Gotta take care of my peeps from the Bay Area.
obender66
18 Inch
Mar 13, 2016 12:20 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
JaeXL
Aug 4, 2015 07:43 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
