Tires worn on stock height!
I am bringing my car in to get my car checked out, due to a recent oil change I discovered my tires are getting bald on the inside. Like as if my car has been lowered, I called three dealers and costa mesa and cerritos wants me to bring the car in to get checked out. Mission viejo service advisor said that its like a sports car, like a porche and that its normal to have toe ware! I will investigate and get back with you guys. This is not normal! when you have a stock car and your getting uneven tireware you have an obvious problem, is it an alignment issue? No because its waring evenly on the toe. I will get back with you guys after I send my car in.
Well our cars have a tiny bit of negative camber from the factory, it helps in handling. What you have is most likely feathering, caused from too much negative camber. This is very known on early model Z's
Fireman07603
Aug 9, 2015 06:00 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
