17" tires
Old Jan 16, 2003 | 06:03 PM
ryoken's Avatar
Re: 17" tires
I'm interested in staying with the stock 17" rims, myself. My understanding is that you shouldn't go wider than 225 on the front, or it won't clear the suspension. Anybody know the truth to that? I also hear that sedans should keep the same tires front and rear, or at least keep the same wheel diameter, or the VDC system goes haywire. Coupe's VDC is programmed to handle soffset tire sizes.
The thing that bugs me, is that 235/50R17 seems like the right diameter to go to, to keep the speedometer, etc., correct. However, it's wider than 225 on the front. Tire Rack's website suggests the 235's, but rumor is that Infiniti recommends no wider than 225 on the front. And, since there are only 3 tire choices in a 215/55R17, there's not much room to maneuver.
Here's hoping that either A) Infiniti says 235 is okay, or B) tire manufacturers start making more choices in the stock size.
Old Jan 16, 2003 | 09:33 PM
ryoken's Avatar
Re: 17" tires
What happens if you turn the wheel all the way to one side and fully compress the suspension? Is the edge of the tire going to catch on some little bolt in the wheel well or rub up against some bar? Anybody know why Infiniti is saying stick to 225 as the max width in the front?
Old Jan 17, 2003 | 08:32 PM
Gordgee's Avatar
Administrator
Re: 17" tires
Carl:
I'm also interested in whether going to that wide a tire has impacted your gas mileage? If you could track it for a while and post your findings, I'd appreciate it. Thanks in advance.
Gord
Old Jan 18, 2003 | 12:47 PM
Gordgee's Avatar
Administrator
Re: 17" tires
I figured that because of the extra width, there would be extra drag from the tires, particularly the non-driven (front) wheels. Someone else posted a while back about a noticeable reduction of gas mileage going to 225s. I was surprised that this would be noticeable, but I figured that a significant increase might be. My intention would probably be to go to 235s.
Anyway, keep me posted. BTW, how significant is the 'tramlining' (following the road surfaces) effect? Is it just big imperfections in the road? Noticeable all the time? Tiring after a few hours at the wheel?
Thanks again, Gord
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
