9.5 front, 10.5 rear
Old Oct 11, 2003 | 04:52 AM
DiamondG's Avatar
I'm getting mixed opinions and I want to get it straight before I plunge into these widths. Will these sizes rub on a G35 Coupe 6MT dropped on Tein S-Techs? I'm thinking 245/35/19 front and 275/30/19 rear.
99 Supercharged Civic Si SOLD
03.5 DG 6MT Coupe w/Aero, Premium, tint, mudguards
Old Oct 11, 2003 | 05:43 AM
RaySur350GT's Avatar
Re: 9.5 front, 10.5 rear
They won't rub if you get the right offsets. Keep in the high 20's and mid 30's and you should not have a problem. Give me the offsets you are thinking about and I can tell you if it will or will not rub.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Oct 11, 2003 | 05:46 AM
DiamondG's Avatar
I believe +22 offset for both front and rear
Old Oct 11, 2003 | 05:53 AM
+22 is really low, you will definately need to roll you fenders with that offset to be safe.
The safe area on the rear is between 3.3"~3.9" from rolling the fenders.
With +22 on a 10.5 rim is 4.38", just a little over the safely area. So I would recommend rolling them b/c of speed bumps and pot holes.
Old Oct 11, 2003 | 05:56 AM
DiamondG's Avatar
Thanks for your quick replies. I'll probably just stay with the 8.5/9.5 combo to be safe.
Old Oct 11, 2003 | 06:00 AM
No Problem!
What kind of rims you looking at anyways? If you are going for lip, offsets make the biggest difference to the size of the lip. I'll try to help you find the best offsets for you to get the biggest lip possible without rolling the fenders.
Old Oct 11, 2003 | 06:02 AM
DiamondG's Avatar
Volk Racing LE37T in silver
Old Oct 11, 2003 | 06:13 AM
Looking at what Ray's available offsets for the LE37Ts in 19x9.5 and 19x8.5 you can go both in +22 (the rear will be safe range 3.88") So you should have no problems running these offsets on a 9.5 and 8.5 rim.
But if you run 10.5 rim with a +22 offset, the lip difference will be dramatic. I will look about 1" more lip (Looks really nice!) Gives it even a more deepdish performance look. But like I said earlier, you will need to roll your rear fenders for that size and offsets.
Th611
Oct 27, 2015 03:48 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
