are g35 6spd sports coupes rims the same?
Old Aug 22, 2006 | 06:46 PM
nfo184's Avatar
i own a 04 g35 sports coupe with the brembo package and 18" rims and didnt know if the rims were all the same...i know the tires are staggered and bigger in the back but is the rim size wider also?? or 18x8 all the way around? on the 6spd coupes?
Old Aug 22, 2006 | 07:32 PM
mr freeze's Avatar
i know on my 06 we have stock rays 19" rims with a 8.5" rim in the front and a 9" rim in the rear..
Old Aug 22, 2006 | 09:21 PM
ebuy929's Avatar
rims are different aswell ...ofsets
Old Aug 22, 2006 | 09:51 PM
nfo184's Avatar
what are the offsets then on a 04 for the front and rear? i know the tires are 225/40/18 in front and 245/40/18 in the rear but the rims is what i need to know
Old Aug 22, 2006 | 09:54 PM
mwarsh1's Avatar
um your incorrect on that one, its 8.0 in the front and 8.5 in the back, this is on the oem 19's
Old Aug 23, 2006 | 08:04 PM
nfo184's Avatar
ok well i still dont know on a 2004 with 18's......what are they in the front and rear?
Old Aug 23, 2006 | 08:29 PM
sjc1789's Avatar
Florida G35 Club
i kno the oem 19's are staggered by a half inch... not sure on the 18's
Old Aug 24, 2006 | 03:05 AM
gizsf's Avatar
On my 04 coupe, they are all 18x8 but they are still marked seperately as front or rear. Can't say anything about offsets....I just am not sure.
Old Aug 24, 2006 | 03:20 AM
zeroscythe's Avatar
im pretty sure the offsets for both are set the clear the brembos... i've sceen people with 06 rims with brembos on their car which means its either +24 offset or more... usually +17 is for the non-brembo.. and the rays oem's are 19x8 and 19x8.5 i believe the stock 18's came the same way... u can always call the dealer and ask.. they still carry the 18's
Old Aug 24, 2006 | 08:42 AM
mr freeze's Avatar
thanks for the correction..i was asuming the rim size was bigger
Old Aug 24, 2006 | 12:09 PM
kel's Avatar
kel
on the 04 with the brembo's they are staggered 18x8.5 by 18x9.5
Old Aug 24, 2006 | 01:15 PM
RBull's Avatar
Rated M
The front and rear rims are the exact same 18" x 8". There is a bolt on the front (removable) preventing the rotation of the wheels front and back. The '05 + with 19's moved up to 8.5" in the rear.
Old Aug 24, 2006 | 02:27 PM
Memphis's Avatar
RBull is exactly correct. The front & rear rims on the 04 Coupes with 6MT's (includes brembo's) are the same size rims (18x8). The tires for the front are smaller than the rears which gives the staggered effect. There is a removable bolt on the front rotor hub that prevents the rear rims from being put on the front. I had to remove this bolt so the aftermarket rims I bought would mount on the front. So, the 18x8 rims are the same size for the fronts and rears but the fronts have a machined hole that fits over the bolt.
Old Aug 26, 2006 | 11:57 AM
nfo184's Avatar
so where can i get a nice set of aftermarket rims that will clear the brembos? ???? wheelmax.com only has the non brembo wheels ......and aftermaket rims arent staggered then for mine right? since there not on the oem rims.....just the tires are
Old Aug 26, 2006 | 01:27 PM
_jb's Avatar
_jb
Photographer
There's usually a page in the owners manual that specs out the wheels. I don't have a 2004, or I'd give you the page number.
Here's the page for a 2005. I hilighted the red part for someone else, so disregard that.
