Sedan and Coupe Wheels?
Old Sep 7, 2006 | 12:23 PM
RIG35Guy's Avatar
Hola all!!
This might be a totally newb question, but are the sedan and coupe lug patterns the same? I have stock 18s and going down to 17s for snow tires for the winter and have a chance to get some OEM 17s, but they're made for the sedan.
Old Sep 8, 2006 | 11:49 AM
kenchan's Avatar
yes, both 114.3x5 lug 66.1 center bore.
but the offsets are different... so you should check that first unless
you plan to buy spacers.
Old Sep 8, 2006 | 12:47 PM
redlude97's Avatar
Offsets for the sedan are much higher, so you wheels will be sunken into the wheelwells more than stock. However, the sedans do clear the brakes on an 06, which I have confirmed. I bought a set locally for cheap and plan to use that for my winter setup. I haven't mounted them to see how they look though, just 1 front to make sure it clears the caliper and rotates freely. If it looks funny i'll pick up a set of spacers since i have OEM 19s anyways which look better with spacers installed
Brodys_GCoupe
Nov 7, 2015 08:06 PM
teamghost
Jul 28, 2015 04:52 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
mushu
Jul 15, 2015 03:55 PM
