AT brake questions
Old Oct 18, 2003 | 03:37 PM
uheenada's Avatar
AT brake questions
I'm looking for to replace my OEM brake pads to after market ones... I found NISMO front brake pads however i can't seem to find rear NISMO pads.. did they released yet?? I found one for 350Z(non brembo of course) will rear NISMO pads for 350Z will fit in my coupe? i want to change all 4 pads at the same time... what other pads should i look for?? stillen?
Old Oct 18, 2003 | 05:58 PM
wjfm1's Avatar
Re: AT brake questions
EBC Greenstuffs are good. The rumor is that the rears will be available October. You can only get fronts now.
2003.5 G35C BL/GR, NAV, PREM, AERO, TINT, SPORT, Splash, V1
Old Oct 18, 2003 | 05:59 PM
wjfm1's Avatar
Old Oct 18, 2003 | 09:19 PM
tbusguru's Avatar
As you have probably noticed the rear produces less dust than the front, that means they wear out a lot slower than the fronts, you do not need to change the pads all at the same time , but you do need to change them in pairs, (front) or (rear), the green pads mentioned are a good option for dust prevention, another alternative is "Hawk" . let us know how it turns out , good luck! [img]/w3timages/icons/smile.gif[/img]
Old Oct 18, 2003 | 10:03 PM
uheenada's Avatar
i guess i'll either get NISMO or Hawk... i'll let you guys keep up to date...
Old Oct 19, 2003 | 03:28 AM
ryoken's Avatar
If you're going to switch brands, it's probably a good idea to switch all four wheels, so you preserve the front-to-rear brake bias.
jsimonk
Dec 22, 2023 03:49 PM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
