Another Tire question for 19s *VDC issues*
Old Oct 14, 2006 | 03:02 AM
Tobal's Avatar
I'm about to get a new set of rims looking at 19x8F +25 and 19x9.5R +30. Will these tire configuration work without setting off the VDC? I'm looking at putting 245/45/19 in the front and 275/40/19. Also will this cause any rubbing with stock height?
Old Oct 15, 2006 | 10:19 PM
nfo184's Avatar
shouldnt u stick with 45 in the front and rear??? or 40 front and rear same sidewall height????
Old Oct 15, 2006 | 11:29 PM
badtziscool's Avatar
I thnk that's a bit too big. You should be running 245/35 and 275/35. the 45s and 40s may rub.
Old Oct 16, 2006 | 12:22 AM
insydiusg35's Avatar
45 series will rub. Definitely go with 35 series.
Old Oct 16, 2006 | 01:05 AM
Tobal's Avatar
I kinda like a little more rubber for the comfort... will there be any problems if the front and rears are off by 5 series? What about 40 series up front and 35 in the rear? Any issues there?
Old Oct 16, 2006 | 06:15 AM
nfo184's Avatar
why not just keep it the same? oem settings on the 18's and on the 19's oem tires are both the same front and rear.....will 40 series rub? and also does it fill the gap better? i'm really low as it is with my lip kit and not even dropped ....will the 19's with 40's sit at the same height as my 18's do with 45series???
thanks.....i'm also curious on why they sell aftermarket wheels and tires with different sidewalls for front and rear when there the same on stock's and on the newer g 19's wheels
Old Oct 16, 2006 | 09:15 AM
SilverII's Avatar
Tire selection is more important if you are concerned about ride comfort. Also, the size you are looking at are not common, they might not make such sizes.
Old Oct 17, 2006 | 12:10 AM
nfo184's Avatar
shouldnt they be 30 or 35 front and rear tho...not 30 front and 40 rear or 30 front and 35 rear????
Old Oct 18, 2006 | 09:37 PM
nfo184's Avatar
Old Oct 19, 2006 | 06:17 PM
nfo184's Avatar
should they be the same? or why are they different?
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
