Need advise from Luff M1 owners
Old Oct 24, 2006 | 04:55 PM
clinthammer's Avatar
Well ive been reading about offsets and what not related to rims. Am still confused from all of it.
Ive planned on the Luff M1 comp gold rims for my 2006 IP 5AT g35 sedan. Thing is with these sizes:
SIZE:
19X8.5, 19X10.5, 20X8.5, 20X10.5
PCD:
5:100, 5:112, 5:108, 5:114.3, 5:115, 5:120, 5:130
I have no idea if 19x8.5 or 19x10.5 will fit. same for 20". And as for the PCD, is bigger (130 vs 100) better?
Thanks,
COnfused G35 owner
Old Oct 24, 2006 | 05:22 PM
Brando's Avatar
Cool
You still need more info.....
You need the off sets.
5lug - 114.3 is the bolt pattern
Old Oct 24, 2006 | 06:00 PM
hmm and how can i find out the offset?
Old Oct 24, 2006 | 06:30 PM
Calvin's Avatar
Overglorified Altima
i think sedan offsets are in the high 30's and low 40's but dont quote me on that cause i have a coupe
your bolt pattern is 5x114.3 aka 5x114
Old Oct 24, 2006 | 06:42 PM
extreme4377's Avatar
Lexus IS350
Mid to high 30s on the front, low to mid 40s on the rear
Old Oct 24, 2006 | 07:34 PM
GReddySetGO's Avatar
You might want to check the sedan forums. I'm not sure if the sedan can fit 10.5?
I would go with 19x8.5, 5x114.3, +38 in the front.
The 10.5 is available in +22, +35 and +45. If the 10.5 won't work in the rear, then you have to use the same size as the fronts. I know 8.5 +38 will work in the rear also.
Dmill86
Sep 6, 2015 08:14 PM
clinthammer
Oct 25, 2006 06:09 PM
GDonkey
Sep 7, 2005 05:41 PM
ILuvMyG35
Apr 11, 2005 05:48 PM
