Tires Tires tires
Well finially Im makin the big jump...(no not getting married.lol) Im about to buy 19" Volk LE37 Gunmetal 9.5 front and 10.5 Rear with +22 Offset rolling on Toyo T1S Proxy 245/35/19 front and 275/35/19 rear ( thanks for all your help martyg35) Besides the toyo T1S proxy's does anyone have any other segestion for daily driver, good ware, and wants a little performance tire? Ph ya and is the differance between TE37 and Le37 the poslished lip...Thanks for all your help guys!!!!
sumitomo---HTRZ-2 directional v pattern tire ... tract A temp A tread wear 220-260 ... great wet and dry perf .. "tire rack" used since 94 on all my mustangs except for drag radial ''nitto NT555R for track.. i plan on putting them on my g as soon as the ''oe'' rubber is gone...
I've been quite satisfied with the Nitto NT555. Good ride, relatively low noise, excellent dry handling although since I don't drive my car in the rain, I can't say how wet handling is. Also, treadwear is rated at 300 so I'm hoping for excellent treadwear.
I just purchaced LE37 19x9.5 f and 19x10.5 rear...Alex from Status (THANKS MAN!!!) Suggested I get 255 up front and 275 for the rear....What are the pros and cons of running 255 unstead of 245???
I'm getting 19.9.5 fronts and 19x10.5 rears and plan to run 255/35/19 and 285/35/19.
The 255/35/19 is closer to the OEM front tire diameter. It will fit a 9.5" wheel without stretching (good if you like the flat sleek look, bad if you like the stretched look). The 255 will protect your front wheel more.
It's hard to find a tire that comes in both 255/35/19 and 285/35/19.
