will this wheel/tire combo fit? please help...
Old Dec 5, 2006 | 09:46 PM
Mr. Me Too's Avatar
i have a 2004 G35 Coupe AT on stock 18s and stock suspension.
i'm lookin at this wheel/tire combo:
TSW Thruxton
19x8 with 245/35/19 for the fronts
19x9.5 with 275/35/19 for the rears
offset choice of 20, 35, or 40
now my question is, which offset should i go with to get the deepest lip possible while keeping the wheels flush with the fenders without rubbing or rolling of the fenders? can i run 245/35 on all 4 or will the rears be stretched?
thanks for any help guys!
Old Dec 6, 2006 | 07:25 PM
Clean G 4D's Avatar
Unless you are set on getting those wheels... I would look around, there are soo many more options out there with better sizes and offsets.
If you must... I would get +20 offset for both front and rear. Then, for nice fitment, I would add 15mm spacers front and rear. You may have to shave/roll your rear fenders if you use the spacers.
This is all coming from a sedan owner, so you should have someone verify this just to be sure its correct. From what I have seen from my coupe brethren, my advice seems like it should work out.
Old Dec 7, 2006 | 01:35 PM
Clean G 4D's Avatar
https://g35driver.com/forums/wheels-tires/128594-will-8-5-front-9-5-back-wheels-two-tucked-coupe-these-offsets.html
you guys are in the same boat...
Old Dec 7, 2006 | 08:25 PM
Mr. Me Too's Avatar
Originally Posted by Clean G 4D
LOL thanks... i did see and read his thread in one of my billion searches for an answer... the difference is i knew the 35 offset would look tucked, but i don't know if going as low as 20 offset would give me any rubbing issues...
Old Dec 7, 2006 | 08:36 PM
Clean G 4D's Avatar
+20 on these wheels should be close to the same fitment as the oem coupe 19's.
FWIW, I have seen some coupes running 19x9.5 +17, and 19x10.5 +18.
So the sizes you are looking at (19x8, 19x9.5) with a +20 are very conservative.
With the right tires, and rolling my rear fenders, I can run those wheels in +35 on my sedan. ... just food for thought...
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Claudiu
Sep 26, 2015 01:04 PM
