Another, Can these Fit Thread
Old Dec 16, 2006 | 04:57 PM
bowzer's Avatar
These would be going on an 03.5 sedan w/350z drop and sport suspension.
Front Wheel-Ruff 279 18x8.5 w/35mm offset Tire-245/40/18 Falken FK-452
Rear Wheel-Ruff 279 18x9.5 w/35mm offset Tire-275/40/18 Falken FK-452
I'm mainly concerned w/the offset and the size of the rear tire fitting.
Old Dec 19, 2006 | 04:35 PM
nchima's Avatar
probably.
Old Dec 19, 2006 | 06:09 PM
az1anbeethoven's Avatar
offset is too low on the rear with a 9.5 width wheel...
Old Dec 19, 2006 | 06:10 PM
if they dont have a higher offset, then i would suggest keep it 18x8.5 all around with +35mm offset and you will be fine with your drop...good luck
Old Dec 21, 2006 | 11:17 PM
bowzer's Avatar
How about if the offset were 38mm for the front and 40mm for the rear?
Old Dec 22, 2006 | 08:31 AM
bowzer's Avatar
or, an 18x8 w/40mm for the front and 18x9 w/38mm for the rear?
cbax
Intake & Exhaust
11
Jul 15, 2023 12:43 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
reavensf
Sep 17, 2015 11:30 PM
BlackGee35
Jul 31, 2015 11:04 AM
