Quick question on rim
Old Jan 18, 2007 | 08:44 PM
ELE's Avatar
ELE
Originally Posted by TopSecret8
^ I agree a 245/35/19 for the front and 275/30/19 for the rears would be appropriate. He mentioned 35 profiles for the rear but the wider rears should have a 30 profile to balance out for the front size.
u sure thats' gonna fit?...my rim(4) are 19"X9
Old Jan 18, 2007 | 11:23 PM
ELE's Avatar
ELE
should i just go for 25mm spacer front and 35mm spacer rear?...i will order it soon.....plz sum help...!!~
or i need more?>.<
Old Jan 18, 2007 | 11:32 PM
Gilley's Avatar
You guys are suggesting staggered tire sizes for staggered rims. All 4 of his rims are the same size - 19x9. He needs the same size all around.
Old Jan 18, 2007 | 11:34 PM
ELE's Avatar
ELE
so (4) 245/35/19 will be okay?
Old Jan 18, 2007 | 11:38 PM
Gilley's Avatar
Honestly, you bought the wrong type of rims. We need staggered sizes. Your rims are perfect for a sedan.
Some guys have put the same size rim all around on a coupe, but it isn't meant to be that way. I'm sorry.
Old Jan 18, 2007 | 11:57 PM
ELE's Avatar
ELE
i know i know=.=....cant' do anything about it....the rims are on its way , and i need a solution......
first spacers
second tires....
Old Jan 31, 2007 | 07:38 PM
redlude97's Avatar
no. the rear oem tires are not 275 width that is why the 35 series height can work. you would not use oem tires to reference if the widths are different. On a 275 width tire, it will sit perfect. Check with any rim/tire shop and thier charts for height comparision when using staggerred sizes. Many have done it and ive seen it.
Im sure both 35 and 30 will work but i would rec the 30 as the 35 will make the rear sit kinda higher.
here's 2 samples of what im talking about:
Front 245/35/19 and Rear 275/30/19 tires
https://g35driver.com/forums/archived-sales/134279-volk-racing-forged-le37t-19-wheels-8-5f-9-5r-22-socal.html
https://g35driver.com/forums/archived-sales/133418-fs-maido-gr5-19x9-26-19x10-5-29-nitto.html
You need to go do some more research, of course a 275/30 is going to look lower, but that doesn't mean its the correct size. Go run it through a tire size calculator and you will see a 275/35 is the correct size to run.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
EasySausage
Jul 14, 2015 11:17 PM
