VS-XX wont clear brembos!
Old Jan 18, 2007 | 09:10 PM
Blackbird V35's Avatar
I have a set of work VS-XX's 19x9.5 +28 with the R disc, and 10.5 Rear +29 with O disc
Has anyone who owns a set had trouble clearing the stock brembos in the back, mine hit. The front ones clear but only by about 1.5 mm and it looks like it might hit the suspension on the inside front.
Anyone had this problem and what size spacers did you use?
Old Jan 18, 2007 | 10:27 PM
redlude97's Avatar
your offsets are high enough that you could run a 5mm or 10mm spacer to get more clearance, just make sure you use some with longer studs
Old Jan 18, 2007 | 10:29 PM
ttrank's Avatar
Grocery getter
Try some 5mm spacers. You can run those without changing your studs.
Old Jan 19, 2007 | 12:29 AM
hoolamonster's Avatar
sell them to me!!! ; ) good luck!
Old Jan 19, 2007 | 01:46 AM
Calvin's Avatar
Overglorified Altima
shoulda got the right offsets...
Old Jan 19, 2007 | 11:39 AM
well i was asked if i had brembos and i said yes, so i thought they would have figured that in
what are your offsets
Old Jan 19, 2007 | 02:23 PM
Calvin's Avatar
mine don't clear a BBK, but mizter_g's do
Old Jan 19, 2007 | 02:27 PM
G35SHAWN's Avatar
Well it's a wrap, therefore just add spacers & enjoy your new wheels.
Old Jan 19, 2007 | 04:11 PM
GReddySetGO's Avatar
Yeah, shoulda got the right offsets. Just get spacers now and run them that way. Or sell them to someone w/o Brembos and get the right offset
Old Jan 19, 2007 | 04:16 PM
Aznteazer's Avatar
dont really like the sound of having spacers on ur aftermarket wheels....
stock yes, but u spent around 4k on wheels so u shud've got wat u paid for.
i say return the rims. u have a good reason that wasn't ur fault.
Old Jan 19, 2007 | 05:22 PM
Calvin's Avatar
^^agreed.
Old Jan 20, 2007 | 12:12 AM
Triple8Sol's Avatar
Run a 10mm spacer front/rear with the longer studs. It'll look beter too.
Old Jan 20, 2007 | 01:22 AM
HXS's Avatar
HXS
uhh... i thought those WERE the correct offsets. lookie HERE
status says in the middle of his post that they clear stock brembos
Old Jan 20, 2007 | 07:27 PM
thats who i got them from but he shipped me a set of free spacers, could it be because of my stoptech rotors? im not sure if the hat is thinner than a stock brembo rotor hat but its a possibility
Old Jan 20, 2007 | 11:57 PM
avs007's Avatar
Those offsets look a little high. My Work Rims are +25 in the front and +20 in the back.
