will a 20x11.5 fit on the rear of G coupe? 30mm offset
Old Jan 24, 2007 | 10:36 AM
g35man04's Avatar
CLUB MODERATOR
like the title says..please help? they are off a 350z and there were no fitment issues. this is why im asking.
Old Jan 24, 2007 | 10:39 AM
IvoryGT's Avatar
I think when you go into 10.5 you need to roll your fenders, and higher than that...I dont even know if it will fit.
Old Jan 24, 2007 | 10:42 AM
g35man04's Avatar
CLUB MODERATOR
ok thats what i was wondering! so a 10.5 is questionable too? I plan on dropping on g35 s-techs as well.
Old Jan 24, 2007 | 10:43 AM
delion21's Avatar
Not true...I have 10.5 on my car with no problems and without rolling fenders. 11.5 you may have to roll fenders or get rear camber adjustment
Old Jan 24, 2007 | 10:44 AM
g35man04's Avatar
CLUB MODERATOR
yeah i knew a camber would be needed....so i would be ok with 10.5? What size tires are you running on that?
izmir41500's Avatar
G35driver Addict
what wheels are you looking at?
Old Jan 24, 2007 | 10:49 AM
g35man04's Avatar
CLUB MODERATOR
they are kaotik Z5.....ever heard of them?
Old Jan 24, 2007 | 10:59 AM
g35man04's Avatar
CLUB MODERATOR
here is another pic
Old Jan 24, 2007 | 11:00 AM
g35man04's Avatar
CLUB MODERATOR
these are my rims right now...19x8.5 all around with 38 offset and 15mm spacers on front and 25mm on rears
Old Jan 24, 2007 | 11:08 AM
MsA's Avatar
MsA
Yeah I dont know about 11.5 but the 20x10.5 should be fine. nice selection btw
Old Jan 24, 2007 | 12:30 PM
g35man04's Avatar
CLUB MODERATOR
thanks!
Old Jan 24, 2007 | 01:16 PM
Kyosho's Avatar
they'll all technically FIT. if you have an aggressive drop then you'll have to roll your fenders because the tire will be hitting the body. at stock height it shouldn't touch under normal driving. a camber kit will only push the top of the wheel out, making the rubbing worse.
Old Jan 24, 2007 | 09:27 PM
delion21's Avatar
285/30/20 with Tein H-Tech Springs
Old Jan 24, 2007 | 09:29 PM
g35man04's Avatar
CLUB MODERATOR
thanks delion!
Old Jan 24, 2007 | 10:51 PM
HYBRID ITR43's Avatar
I have 19x9.5 in front with 245/35/19 tires and 19x10.5 in back with 295/35/19 and the car is dropped fairly low. No issues what so ever. No rolled fenders.
I'm sure you can do 11.5 in back no problem. You won't need to roll anything, just get proper sized tires. maybe some 285's.
