20s no drop, camber work ... ?
Gents,
Can any comment on 20s on the g35 coupe with no other mods whatsoever, I'm in an '03 and looking at a set. I possilbe please pos some pics of this set up if there are any along with wheels specs, sizes and offsets as well as tire sizes. Help would be mucho appricated I would hate to end up with a set of rims and then have another $1000 in work needed to make them sit right. Thanks in advance.
Originally Posted by az1anbeethoven
if you dont drop, your camber will not be affected...
No camber work but i dropped it maybe 2.75" back and 2.5" in the front somewhere around there and no alignment problems, but dont get me wrong i will be purchasing a camber kit soon
I just did 20's with no drop and I think it looks great. Check out the thread below for pics. Personally, I am not a fan of lowered cars though.
https://g35driver.com/forums/wheels-tires/138848-need4speedmotors.html
you would think stock suspension would mean no camber issues, but that's not the way it actually works. I'm on stock suspension and with 20x10 in the back with a 285/30/20 and there is a lot more negative camber then with the stock 18" wheels on. You can see in this pic how much the tire leans in.
Lol. These cars come with negative camber stock for better handling, but that is not a lot of negative camber at all. You should see how my tires are leaning in right now and I am only dropped on H techs, had to order a camber kit or else I would have had issues. But if you do put 20's, definitely drop it. I thought I ddint have to, but with the drop it looks soo much better.
Here's mine on 20x8.5 & 9.5. Sorry dont' recall the offsets. Tires are 255/35 Fr 275/30/20 Rr.
https://g35driver.com/forums/wheels-tires/63406-wait-over.html
