Actual weight of OEM 18s (rim only)
Old Feb 5, 2007 | 12:31 AM
Need4SPEED05's Avatar
Whats up guys, I've been searchin the site to find an exact answer for this. Couldn't find any luck so does anyone know the exact weight of the oem 18s (I believe there is only one type, 30mm offset 18x8). The reason I ask is because I bought a set from ebay that are not originals but a replica and wanted to see how they compare. I just weighed them and the ones I bought are 27lbs a piece without tires so I wanna see how it stacks up to the original. They acutally feel heavier than my oem 19s. The quality and finish of the rims look top notch so just want to see how the weights differ on each. Thanks.
Old Feb 5, 2007 | 10:35 AM
Ginsengboy's Avatar
They are around 25 lbs if i can remember correctly. I weighed them on my bathroom scale with my holding onto them. So, it could be off by 1-2 lbs.
Old Feb 5, 2007 | 10:42 AM
madchef's Avatar
IIRC the OEM 19's were around 22lbs, and the 18;s were a bit more. 25 sounds about right, maybe a few more.
Old Feb 5, 2007 | 10:43 AM
Nismo G's Avatar
18s were 24 pounds
17s were 25 pounds
Old Feb 5, 2007 | 12:46 PM
Thanks for the responses. I guess 2-3 pounds more each rim. Not so bad for a replica i guess. Anyone want a set of oem 19s without tires. No curb marks and 1 has about a 1 inch scratch. PM me if interested.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
TheKnite
Aug 14, 2015 07:59 PM
NemesisGee
Aug 11, 2015 07:10 PM
