from 18" oem to 19" oem
Old Feb 6, 2007 | 07:07 PM
redmy's Avatar
is this a direct fit? or would i need spacers??
Old Feb 6, 2007 | 07:09 PM
Calvin's Avatar
Overglorified Altima
itll go on fine. but in either case, oem 18s and oem 19s, youll need spacers to make the wheels flush.
Old Feb 6, 2007 | 07:17 PM
redmy's Avatar
do u know what size would i need?? oh yeah ahero.. i sent u a pm..^_^
Old Feb 6, 2007 | 07:26 PM
Calvin's Avatar
i'm not 100% but i think the specs for oem 19s are:
19x8/8.5 with +27 front and +33 rear
you can decide how big of spacers you want after you factor in what size tires you are/will be running, how much you are/will be lowered, if you are okay with rolling your fenders or not.
Old Feb 6, 2007 | 08:56 PM
redwillow's Avatar
20 Year Member
direct fit...you will just have to pull off the front fitment bolt.
Old Feb 11, 2007 | 09:58 PM
2001Z71's Avatar
what is the front fittament bolt?
Old Feb 11, 2007 | 11:07 PM
redlude97's Avatar
Actually you won't since they are both OEM wheels, they both have the clearance for the bolt
Old Feb 12, 2007 | 12:44 AM
AthensBlueG's Avatar
Brian
This is correct, because I've done this. My coupe came with the 19"s, I bought a set of 18" OEMs to run in the winter, and they fit on there just perfect. The front fitment bolt works with both the 18" and 19" OEM setups.
I'm not sure about the spacer comment Calvin made though. Why would you need spacers for OEM wheels?
Old Feb 12, 2007 | 01:18 AM
Calvin's Avatar
lots of people have put spacers on their oem wheels and it makes a huge difference. maybe not to non-g-owners but i can definitely tell the difference. ive seen a coupe with oem 18s plus spacers in person and it looked much better. ive seen pics of oem 19s with spacers and those looked great as well.
Old Feb 12, 2007 | 01:54 AM
2001Z71's Avatar
any downside with spacers? what is a good size to get?
Old Feb 15, 2007 | 09:50 AM
2k2maxx's Avatar
are u going to be selling ur 18s??
Old Feb 15, 2007 | 02:47 PM
redmy's Avatar
yeah probably.. you interested?? pm me
Old Feb 15, 2007 | 10:50 PM
2k2maxx's Avatar
pm sent
Old Feb 16, 2007 | 03:14 PM
jjellyneck's Avatar
Are the rear wheels really 8.5?
Old Feb 16, 2007 | 03:42 PM
redlude97's Avatar
Yes, on the 19's they are, but Ahero got the offsets wrong, front is +30 while the rear is +33
