Help w/ Racing Harts
Old Nov 30, 2003 | 02:48 AM
notstr8mia's Avatar
Hello, I just ordered a set of racing hart's 19x8.5 and 19x10 for my G35 Coupe w/o Brembos... the guy at the wheel shop said the offset he ordered is +26 in the front and +21 in the rear, does this sound right ? I also have ordered Tein Coil Overs... and was wondering would I have rubbing issues with with this set up on 245/40/19 & 275/35/19... Any help would be appreciated... I am looking to get the wheel as close to the fender as possible.......
Carribean Blue 2004 G35c w/Navi
Black / 2003 Nissan 350Z Touring / 19" I-Forged Wheels / Cusco Sway Bars / Tein Suspension
Old Nov 30, 2003 | 07:07 PM
Premier's Avatar
Re: Help w/ Racing Harts
Looks about right since you don't have the brembos............just make sure to test the fitment before you have the tires mounted. You shouldn't run into any rubbing issues, but just to be sure don't mount the tires............jack up your car and put a wheel onto the studs. Next, place a jack under the lower control arm and start jacking it up to move the wheel past the fender line. If you clear it that way, then you shouldn't have any rubbing issues w/ this setup. Do this for both the front and back................with about 10mm of spacing for the front is sufficient for the wheel to not rub the fender.
Pearl White 2003 Sedan & 2004 Coupe 6MT
Certified Window Tint & Detailing Specialist
Clearshield ("Clearbra") Authorized Dealer
Madico Authorized Dealer
www.machiii.net
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
jilljann1
Jul 21, 2020 08:12 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NJ6MT
Oct 9, 2015 05:02 PM
kevintandmd
Sep 3, 2015 06:41 PM
