Sedan Wheel Fitment Chart
Old Jun 9, 2008 | 07:12 PM
  #136
THX723's Avatar
G Kreuzer
Originally Posted by Sagemark
Thanks. That's consistent with what I've found so far on the subject. I've read of 275 section tires on 9 1/2" wheels being successfully fitted, 9 1/2" is plenty for 275's and 285's are simply too big to fit in the wells so it seems that's the limit for putting wide rubber in th rear. Unlike the coupes and 350z's there just isn't a lot of scope.
Welcome.
285 + 9.5" with enough negative camber (on the order of over 2-deg) and the right offset can work. That is about the absolute max one could achieve. But again, if you have coilovers then better stay way because they will hit when cornering or hitting bumps -- a seriously safety hazard. I know this from first hand observation, but thankfully not mine.
Old Jun 10, 2008 | 05:48 AM
  #137
hiropowers's Avatar
Originally Posted by RxSedan5AT
Ok guys, I just mounted a set of SF-challenges on my ride:
19x8.5 +34, 245/35/19 Nitto 555s
19x9.5 +40, 275/30/19
I also have a 1" Eibach drop. The fronts look great, no rubs no probs; perfect. As for the rears, it rubs ever so slightly on bumps. I will have to roll the fenders. A +48 offset would probably not have rubbed. It's NOT a good idea to go any more aggressive than +40 for rears on the setup I have. But I have to admit......it looks WICKED!!
Do you have any pic's? I'm thinking about:
Tein s-tech springs (sold as 350z springs)
19x8.5 +32
19x9.5 +40
I think I will need the rear's rolled...
Old Jun 10, 2008 | 10:29 AM
  #138
Sagemark's Avatar
Originally Posted by THX723
Welcome.
Depends on which 285's then. I have a set of 285 Hoosier R6's and the section width is 11.5". Measured from the rear shock to my rolled inner fender it is only 11.3" so there's NO way they could ever go in. Other 285s may well have narrower sections. Even with 275s it's so close I can't imagine why anybody would really want to push it to 285's where the clearances become none-existent.
I'm running 18"x8" +33 coupe wheels on the street. I'm thinking about having the rears widened to 9.5" to accomodate 275's, especially if I actually go for major power upgrades. (I'm thinking of cams, headers and Osirus tune for stage one, STS turbo for stage 2 and a built block and increased boost for stage 3)
Old Jun 12, 2008 | 05:17 PM
  #139
AS007's Avatar
Im running a Toyo T1R 285/30/19 in the rear of my 05 Sedan, it is lowered on Tein S techs. A 9.5 in wheel....
Old Jun 13, 2008 | 05:45 AM
  #140
hiropowers's Avatar
What is the offset of those rears? Do you have rolled guards? Pic's would be cool
Old Jun 13, 2008 | 07:28 AM
  #141
G35sedan03's Avatar
i'm running 275/35/19 on a 9.5" wheel with +45. lowered on coilovers, very aggressive drop and used to rub, raised it 1/2 in and it's perfect, no more rubbing and the wheel sits flush, looks great.
Old Jun 13, 2008 | 07:32 AM
  #142
hiropowers's Avatar
Sounds awesome! I get my Tein s-techs' next week and plan a rear camber kit... cannot wait!!
Old Jun 15, 2008 | 07:54 PM
  #143
AS007's Avatar
Offset is +55, no rolled guards.. I will take some pics tomm and post them up.
Old Aug 8, 2008 | 07:34 AM
  #144
racingracing's Avatar
Hi, I need some recommendation. I'm going to buy a set of 19" rims, all around non-stagger setup for my 03 sedan. The rims will be in 19x8.5 but I have a choice of +35 or +45 offset. I'm going to use 235/35/19 tires all around. I wonder which offset is better?
I read through this message, I know the back should be +45 for sure, but then should I use +35 for the front? or what if I buy +45 all around, in case the front is too "inside", I use 3mm spacer or something?
thanks for any input.
Old Oct 26, 2008 | 04:12 AM
  #145
GPL777's Avatar
I recently picked up a set of wheels for my 04 sedan. They're 18x8.5 with 45 offset. My question is will they fit on my sedan without any rubbing? I like the wheels but I don't want to invest into some tires if they aren't going to work. tia!
Old Nov 10, 2008 | 02:31 AM
  #146
heyitzalex's Avatar
northsideracing has 19x9 +45, 19x10 +45 on a dumped setup. He clears in the inside suspension fine on the fronts.
I'm currently on 20x9 +38, 20x10 +44 and it cleared the inside front suspension fine with about a finger gap.
Old Jan 1, 2019 | 09:36 PM
  #147
Kyle Landrith's Avatar
Sedan 5AT
I'm thinking of running a square tire/wheel setup with 255/35R19s with a +42 offset. Specially these wheels...
https://www.summitracing.com/parts/enk-4299956542hb
Looking at the fitment chart it looks like I will hit the front suspension upright? Is the the correct understanding? It also looks like I will need to roll the fenders. I read somewhere on here of a member running this tire size with a +38 offset on an 8.5 inch rim I believe and having no problems. Any input would be appreciated.
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
joedaddy1
Jul 28, 2015 02:58 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
Soumilg
Jul 18, 2015 12:33 PM
