Wheel experts quick offset Q.
Old Feb 13, 2007 | 07:13 PM
Bigguy2000's Avatar
I am looking at new wheels and found a used set of Volks i'm interested in. Haven't seen wheels in person but rears are 9.5 w/ 29 offset. Can anyone tell me their best guess at the "lip" size ? I know it won't be huge but I prefer a more conservative lip ,,,,,,,, me is old,heh,heh.
Old Feb 13, 2007 | 08:29 PM
Calvin's Avatar
Overglorified Altima
lip sizes cannot be calculated or estimated from the wheel width and offset alone..
different wheels with the same width/offset would yield different sized lips
btw, a +29 on a 9.5" wheel = bad for the coupe (as far as looks go, imo)
Old Feb 14, 2007 | 10:17 AM
Bigguy2000's Avatar
'BAD FOR THE COUPE'' .............. Hero, do you mean as far as sitting too much inside fenderwells or ???
I've seen pics only of thesewheels on a coupe and they seemed fine. Give me more info guys!
Old Feb 14, 2007 | 10:24 AM
papiloco21's Avatar
whoa bad for coupe?....29 on a 9.5 and I had to roll my fenders....it will look good.
Old Feb 14, 2007 | 10:45 AM
o0MrJujuBee0o's Avatar
A +29 offset on a 9.5 wide wheel will stick out about half an inch further in the front and a little more than a half inch for the rear compared to the OE wheels. Did you drop it too much to need the fenders rolled?
Old Feb 14, 2007 | 11:10 AM
Calvin's Avatar
i was barely happy with my +24 on my 9.5/10.5 wheels. maybe i'm just more picky...i want mine to stick out a tad bit more..
imo, offsets for the coupe should not be any higher than +25 as far as my opinion goes on the "aggressive" look.
papiloco, what sze tires you have?
i have a 10.5" with a +24 in the rear, am lowered on z h techs, and only shaved my fenders because of my 285s. if i went 275s i would have been fine.
Old Feb 14, 2007 | 12:33 PM
papiloco21's Avatar
275/40/19 in rear on 9.5 rim 27 offset
larger sidewall for ny offset
papiloco21's Avatar
and 245/45/19 on 8.5 with 24 offset up front
Old Feb 14, 2007 | 12:48 PM
Bigguy2000's Avatar
Thanks for the help. I think I will be OK as the 29 offset in rear looks fine in picsof coupe currently runnng these rims. As an "old fart" I'm more into a less radical lip and this appears to be 2-3 ' in rear so fine by me.
If anyone else has comments please post 'em up .......t hese wheels going on my'06 black coupe.
Also,thanks to Hero for a quick reply to my PM. Most appreciated.
Old Feb 14, 2007 | 01:11 PM
papiloco21's Avatar
just post pics once you get them on!
Old Feb 14, 2007 | 02:40 PM
Calvin's Avatar
np. i'm sure they will look fantastic on your g. good choice in wheels..just make sure you drop it
Old Feb 14, 2007 | 03:55 PM
redlude97's Avatar
I'm running a 9.5 +30 with a 285/35/19 in the rear, and while is not ideal, and certainly not flushed, it doesn't look too bad, and its pretty close to rubbing already. More aggressive offsets will likely require a roll in the rear which some people are uncomfortable doing. Heres some pics showing you what it looks like.
Old Feb 14, 2007 | 05:10 PM
Calvin's Avatar
^^youre close to rubbing because of the 285s and those custom springmounts tho, lol
Old Feb 14, 2007 | 05:32 PM
redlude97's Avatar
And I haven't even gotten an alignment yet! With that I think i'll have 1-2mm of clearance, but I'm gonna roll and get some spacers, and then I'll be back to 1-2mm of clearance
Old Feb 14, 2007 | 05:37 PM
Calvin's Avatar
you still havent gotten an alignment yet? lol didnt you do that mod a looong time ago? lol
the spacers will do wonders
