Torquing new wheels.. how many ft. lbs?
Old Feb 20, 2007 | 11:22 AM
Bigguy2000's Avatar
Believe stock 19" rims good to go at around 85 ft./lbs.
Anyone know if that amount OK for aftermarket Volk SF Winnings? Thanks for your help.
Old Feb 20, 2007 | 11:25 AM
filanj's Avatar
did you try the volk site?
Old Feb 20, 2007 | 02:00 PM
Chico's Avatar
I keep my wheels (winter & summer) at 85 to 90 lbs.
Old Feb 20, 2007 | 02:05 PM
DHCrocks's Avatar
same as stock around 85 is good. the amount of torque actually depends on the lug size not the wheels. with new rims you should recheck the torque after a couple of days as they will settle into the aluminum a little and need to be retorqued.
Old Feb 20, 2007 | 02:11 PM
gary c's Avatar
Smart Idea.......
I torq my wheels at 85 ft lbs! Don't ever let anyone use a impact gun on
your rims plus they are the cause of warped discs too.
Old Feb 20, 2007 | 04:49 PM
G35Luv's Avatar
Oh crap, I thought it was 80 ft lbs. I better go re-torque mine if that's the case.
Old Feb 20, 2007 | 05:10 PM
Brando's Avatar
Cool
Anywhere between 80 - 90 lbs and you should be ok on almost any wheel.
Old Feb 20, 2007 | 05:52 PM
Bigguy2000's Avatar
85 it is ..... thanks to all
Old Feb 20, 2007 | 05:54 PM
superdds's Avatar
88...only cuz i'm chinese
Old Feb 20, 2007 | 09:18 PM
kenchan's Avatar
i use 85-90.
your studs will break before your volks, i think.
Old Feb 20, 2007 | 09:52 PM
GTR_Boy's Avatar
Alloy wheels 80~85 lbs
Steel wheels 90 lbs
Old Feb 21, 2007 | 01:52 PM
kenchan's Avatar
Steel wheels 90 lbs
is that from the owner's manual? cause as i mentioned above, i think the
limiting factor are the studs.
Old Feb 21, 2007 | 01:54 PM
Big Joe Joe's Avatar
120 Ft/lbs
Old Feb 21, 2007 | 02:07 PM
Jeff92se's Avatar
Red Card Crew
That's WAY too much. FSM states 72-87 ft lbs. Page MA26.
Originally Posted by Big Joe Joe
120 Ft/lbs
Old Feb 21, 2007 | 02:12 PM
