Volk GT-V +24 offset?
Old Feb 23, 2007 | 04:06 PM
AD_LIB's Avatar
I found a thread about this a long time ago, but no concrete answers, will a Volk GT-V 19x9.5 +24 fit up front on an 04 coupe with brembos? If not do I need to run a +30?
thanks
-Brian
Old Feb 23, 2007 | 05:19 PM
ibsturbin's Avatar
It is possible, but not recommended. You may need anywhere from 5-15mm spacer. Volk also offers a +30 or +17 offset if you want it more aggressive and does not require rolling. Ask any of the authorized Volk vendors here. I'm sure they can help you out.
Old Feb 23, 2007 | 06:44 PM
Ciabatta Burger's Avatar
i have gt-7s with +24 offset all round and i was told by many people that u can only do +24 with non brembo brakes and u cant go BBK either. but on the plus side i get a 3.5 inch lip in front and 4 in back...
Old Feb 23, 2007 | 06:54 PM
AD_LIB's Avatar
will the +17 clear the fenders up front ?
Old Feb 23, 2007 | 08:21 PM
Triple8Sol's Avatar
+24 would be ideal. +17 might cause some issues depending on your drop and tire size.
Old Feb 23, 2007 | 09:07 PM
AD_LIB's Avatar
so basically if you have the Brembos you are stuck with +30 up front. Thats good to know.
Old Feb 25, 2007 | 02:52 AM
k67p67's Avatar
BBK clearance depends as much on pad size and spoke design as offset. I have Volk GT-7s (19"x8.5" +23 high disk) and they clear my Rotora 6-pot BBK with plenty of room.
Old Feb 26, 2007 | 05:02 PM
AD_LIB's Avatar
after searching some other posts i found that the +30 offset for the GT-V is very conservative, and actually the +17 seems like a better move as long as you aren't going to drop the car like 2 inches. (this is with the A offset)
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
