Hey Edretti . calculator ??
Old Dec 8, 2003 | 04:38 PM
Triji's Avatar
I was messing w/ the wheel calculator... Going from 245x45x18 to 285x30x19 there is a 3.6% difference with the speedometer being to fast. Now from 245x45x18 to 285x35x19 the speedometer reads 0.6% to slow. Is that calculator off or is the 35 a better match on the 19's for the rears?
Thanks man
peace
2004 Coupe, 5AT, Twilight blue / Willow int. Clear corners, Hypers. 18's, Aero, tint, Premium.
Old Dec 8, 2003 | 04:51 PM
Carlos3186's Avatar
Re: Hey Edretti . calculator ??
no the calculator is right the 30 will be to small u need the 35s. if u run 275s its a super close fit.
good luck
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Dec 9, 2003 | 04:18 PM
Edretti's Avatar
He's right. There is no way you can run a 45 in the front with a 35 in the rear. The set up should be 245/35 front and 285/30 rear. That will put you to 0.1% too fast which is the closest you can get to perfect.
Edretti
2003 Infiniti G35 Coupe 6mt Loaded Brillant Silver
http://www.cardomain.com/id/edretti
Old Dec 9, 2003 | 04:56 PM
Triji's Avatar
actually the numbers represented were for rear tires in both cases. The calculator was saying the 35's are a closer match to the originals than the 30's. I wouldn't even consider 45's in the front, 35's is the size for the fronts... just wondering on the rears from 30's to 35's.... 45's are the size of the original tires on there right now.
2004 Coupe, 5AT, Twilight blue / Willow int. Mtek Xenon Fog/High, Clear corners, Hypers, 18's, Aero, tint, Premium.
wuzz-upp
Oct 3, 2015 04:21 PM
CV35Driver
Sep 15, 2015 05:09 PM
Jyounya
Sep 12, 2015 04:03 PM
gatorglaze
Sep 10, 2015 12:03 PM
