I'm tire dumb. Size compadability question
Old Mar 17, 2007 | 08:24 PM
G35 Mass's Avatar
Will 245/45ZR18 fit on the 18/8 factory wheels?
Old Mar 17, 2007 | 09:15 PM
jjyellow's Avatar
yep
Old Mar 17, 2007 | 09:16 PM
TopNotchG's Avatar
they sure will
Old Mar 17, 2007 | 09:28 PM
BadBoy06's Avatar
tirerack.com for more info
Old Mar 17, 2007 | 09:50 PM
LudwigB's Avatar
Yes, just had four 245/45 18in. put on my car. But I wouldn't go beyond 245 for the front tire. The upper control arms on the front suspension are about to scrape onto the inner tire's side wall. Here are the pics from another thread:
https://g35driver.com/forums/wheels-tires/145384-need-new-tires-2005-ss-18-s-suggestions.html
Old Mar 17, 2007 | 10:39 PM
G35 Mass's Avatar
I searched tirerack.com for more info, and I can't find jack about wheel/tire compadability.
I'm thinking of getting these hoe's from EBay. (I have stock 17's now, with winter tires on. Want to do summer/winter wheel setups rather then remount tires
http://cgi.ebay.com/ebaymotors/18-8-...QQcmdZViewItem
Just need to confirm the offset comparability
Old Mar 25, 2007 | 04:30 PM
GuyLegend's Avatar
Those are coupe spec. wheels, meaning they have a 30+ offset. They are supposed to fit 03-05 sedans too though...
Also you may want to check out how much the wheels weigh since they are replicas. I'm thinking to buy from the same sellers, the black G35 wheels for my IP coupe.
Old Mar 25, 2007 | 04:46 PM
G35 Mass's Avatar
Looks like everything should fit up nicely. At the widest point, the tire will be .8" wider on each side of the hub. If not, I guess I'll be learning about spacers...
Re the seller: he has a pretty impressive track record of customers, so I feel comfortable buying from him.
marsman328
Northern California
Aug 11, 2015 07:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
