Can I run 235/50ZR17 on stock rims with clearance?
Old Mar 23, 2007 | 10:21 PM
watchinggoodman's Avatar
Does anybody know if I can put 235/50ZR17 Kumhos on the stock 03 alloy
17" rims and have enough clearance?
Thanks
Old Mar 23, 2007 | 11:36 PM
DieselX's Avatar
Yea, no problem.
Old Mar 23, 2007 | 11:41 PM
RichardxG35's Avatar
yeah you won't have a problem... but why 50?
Old Mar 23, 2007 | 11:51 PM
ttrank's Avatar
Grocery getter
It is going to be taller than the stock wheel so your speedo will be off. You should run a 235/45.
Old Mar 23, 2007 | 11:53 PM
r u going 235/50/17 all around?
Old Mar 24, 2007 | 09:12 AM
GGRJR's Avatar
The 235-50-17 will be 26.251 tall vs 26.3 for the stock 215-55-17. The speedo error will be non existent.
Old Mar 24, 2007 | 12:44 PM
OCG35's Avatar
Thanks
That's exactly what I have - same brand, same size, stock rim... it is as close to OEM diameter as you can get. You will be fine.
Old Mar 25, 2007 | 05:14 PM
TwiBlueG35sedan's Avatar
I want to take the same route also. Once the tread life expires, I would replace the stock Bridestone with some 235/50/17 tires also.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
StephonW
Aug 5, 2015 12:05 PM
Ashton35
Jul 22, 2015 09:19 PM
Ashton35
Jul 17, 2015 10:11 AM
