rear ir rubbing!!!!
Old Mar 10, 2008 | 11:17 PM
Sylvan lake V35's Avatar
Originally Posted by MPK1232
i have 285 rears +18 offset on stock suspension and i rubbed a lot. i had my rear fenders rolled & now im fine, no rubbing issues at all. but there is no way i can lower the darn thing with those fat tires. now im just waiting for my rear tires to wear out and get 275/30's before i can think of lowering my car. it doesnt look like you have an aggresive offset so you probably can either choose between a smaller tire or to roll your fenders.
I have +18 and 285s lowerd on Bilstiens no rubbing at all. They rubbed stock until I had my fenders rolled.
Old Mar 10, 2008 | 11:21 PM
gary c's Avatar
Only way to stop the rubbing in the rear properly is to get the rear fenders rolled. Putting on lowering springs is only going to make things worse
^^^^100%^^^^have the rear fenders rolled. Only other choice is to sell
the wheels and get off-sets that would work better with your car....roll the
fenders!
Old Mar 11, 2008 | 12:27 AM
GLuXuRy's Avatar
put on a 15mm spacer .. slam it 4 inches .. stretch the tires down to two sizes smaller and put the camber at -2 degrees
jk =)
roll the fenders or cut them (suggest rolling)
SPC rear camber with toe bolts .. a lil negative camber
yosip1115
Aug 20, 2015 10:30 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
Tylerttn
Aug 10, 2015 07:13 AM
jjohns2711
Aug 5, 2015 08:58 AM
Soumilg
Jul 18, 2015 12:33 PM
